Rasterization bug?
Posted: Tue Jan 21, 2020 10:14 pm
Hi, I'm using v2.11
I whanted to save a normal map as a image file so I whent to rasterization window and if you choose for output "Image" rather than "Raster" Image seems to allways output RGB no matter what you select as active layer and independently of what is shown in the preview.
For this case of the normal map, outputing as raster did the job, to me it beign as .png instead of .jpg, is ok.
girl names meaning betrayal
funnye enough for exporting PCV iluminance I coudl not use raster because creates very rare bandings, so I had to bake as RGB color and print as image (which aparently only render RGB no matter what channel is active).
