System Requirements?
Nightmare
Post by Nightmare »
Is there any system recommendations for CloudCompare? Mostly I ask is for when exporting to a DXF file, it takes forever. I am not sure if a better CPU or GPU would be the solution or if its the amount of information that is trying to be exported. The files end up being 300MB+ and it takes an hour or more. We are currently using the program on laptops with i7's and anything from a GTX 960M to a mobile GTX 1650, which it works fine for viewing but again, not for exporting.
Re: System Requirements?
Well, the problem might be more on the DXF file side. This file format is very 'large' and very bad for storing points. Writing (or reading) points to/from a DXF file takes ages. It shouldn't be used to transfer more than a few thousand points...
