Problem saving as las
OogieBoogie
Post by OogieBoogie »
I am using latest stable version 2.10.2, win64
When I try to save a cloud as las I get the following error message:
PDAL exception 'writers.las: Invalid value '0' for arguent 'minor version'.
Saving to bin or e57 works fine for the same cloud. Material is National land survey of Finland open data which has worked fine before (on some older version, which I forget).
Re: Problem saving as las
Can you try with the 2.11.beta version? (I believe this issue has been fixed)
