PCD pointcloud file displays as perfect grid.
Posted: Wed Apr 01, 2020 11:16 am
by Charlie_Lima_Hotel
I opened a PCD file that is from a LiDAR scan. When I open the file it displays as a perfect vertical and horizontal grid no matter how I tilt it or how much I zoom in the points are always DISPLAYED as a perfect grid and always vertical and horizontal. When I pick a point it will pick points as if they were between the "Grid" and seem to be correct numbers. It is just the display that is hokey. I typically use las files and this is the first .pcd file.
Re: PCD pointcloud file displays as perfect grid.
Posted: Thu Apr 02, 2020 4:02 pm
Are the coordinates very large maybe?
Or can you share the file with me? (admin [at] cloudcompare.org)
