Rigid transformation matrix units of measure?
Posted: Wed Apr 22, 2020 11:11 pm
I have a rigid transformation matrix generated after using the ICP registration between two different point clouds. When visualizing the shift between the non-registered and registered point clouds, it is obvious that there wasn't much of a shift (at least in the x and y coordinates). However, when looking at the transformation matrix, the translation vector is very large which leads to my main question. What units does the matrix use? I'd except the matrix to use the same units as my point cloud (which would be meters in my case). I am assuming there is some information I am missing about how transformation matrices work in CloudCompare.
The matrix generated:
0.999282360077 -0.002026880626 -0.037824779749 428.433746337891
-0.001172434655 0.996433913708 -0.084369190037 783.407348632813
0.037860892713 0.084352985024 0.995716392994 -15207.101562500000
0.000000000000 0.000000000000 0.000000000000 1.000000000000
I attached a picture of my point clouds before and after registration. Not the best I could provide, but it should be enough to see that not much of a shift occurred in comparison to what the matrix says.
