Ground segmentation/filtering
Posted: Mon May 04, 2020 8:13 pm
by Ahmed59
Is there any way to select the ground points from a Lidar point cloud data (PCD)? I need to remove the ground points from a pcd file.
Regards,
Ahmed
Re: Ground segmentation/filtering
Posted: Wed May 06, 2020 8:35 pm
You can try to extract them with tools such as the qCSF plugin? (https://www.cloudcompare.org/doc/wiki/i ... F_(plugin))
