![Image](https://i.stack.imgur.com/ERrFP.png)
The units have set but based of this post it must not be set to specific unit :
> STL files are unit-less, so they don't contain the actual units. Most
> people use mm, as that is what all of the 3D printing slicers seem to
> expect. When you import the file, you can set the units to import in,
> and then the scaling should be correct.
When i changed the unit in freecad to meter also be using the distance tools i get same as before ( when it was on its default as mm!) like this:
![Image](https://i.stack.imgur.com/TN7K4.png)
That process video could be seen here.
so i think it must be have one default data which freecad based of that convert the points distance to new units and dont know how it done/
anyway my problem is the cloudcopmare which based of this post have not any specific unit setting :
> Mesurements are expressed in the same units as your clouds.
> CloudCompare doesn't handle units (what we call 'implicit units').
> In your case it looks like it's in millimeters? Or fractions of inches
> maybe?!
Now i have two stl file like this:
![Image](https://i.stack.imgur.com/f8u3t.png)
which give me this output data like this:
![Image](https://i.stack.imgur.com/XdQRd.png)
And the question is the c2m distance are based of what? ( mm or 1/x of mm ),
so for example the difference for first point of target stl file with reference is -3.303671 mm or etc unit!?
Do i need to ask about the setting of scanner device or can i found it by myself?
The reference stl file could be downloaded from here and the targets to be compared with it also uploaded here.
I guess it must be mm but not sure and asked here to be clarified.
Thanks.
