Importing and processing Dense Cloud Data from Agisoft Photoscan
Posted: Mon Jul 13, 2020 4:51 pm
by Geronimo Röder
Good Evening!
I am a master student from Germany and i have a problem in importing Dense Point Clouds to CC which i created from UAV-Data in Agisoft Photoscan.
In Photoscan, the Cloud seems quite dense, almost like an Orthophoto. But imported in CC, it transforms itself in a kind of sparse raster-shaped cloud which is far more sparse than the original cloud seemed. This also influences the Quality of an processed Mesh for example, which shows a very bad quality, in contrast to the mesh from Photoscan. It seems like only a certain range of points is visible and used for processes- i already got through all display options and didn't find anything fitting.
Also, after re-importing a segment of the point cloud back to Photoscan, the rough raster-like shape stays.
Did somebody had a similar problem?
Best regards!
Geronimo
Re: Importing and processing Dense Cloud Data from Agisoft Photoscan
Posted: Tue Jul 14, 2020 8:20 pm
Has the point cloud large coordinates maybe? If yes have you accepted to apply the 'Global Shift' as suggested by CloudCompare?
What you describe looks a lot like accuracy loss because of large coordinates... Applying the 'Global shift' is only temporary and the original coordinates will be restored on output.
Posted: Sun Jul 19, 2020 11:49 am
by matknaak
Hi Geronimo & Daniel,
I agree with Daniel, it sounds like some decimal places might have been cut.
So coordinates will be restored after global shift and re-safe, but what I have been dying to ask Daniel for ages is, if you generate some new processed point cloud from the original, e. g. by applying a tool like subsampling, will this new point cloud also get the restored (shifted) coordinates, and if not, how can I simply achive this?
cheers
mat
Posted: Sun Jul 19, 2020 2:45 pm
Well, normally most of the algorithms should preserve the Global Shift information (if not then it's a bug - or there's a good reason).
