Set point clolor in ccPointCloud
kasper
Post by kasper »
I try to set different color by the point index in pointcloud.
But it always crush.
for( int i=0; i<cloud->size(); i++)
	ccColor::Rgb color;   //same color for example
	color.r = 255;
	color.g = 0;
	color.b = 0;
	cloud->setPointColor(i, color);   // this line always crush.
Could you please offer the correct sample code for this function?
Re: Set point clolor in ccPointCloud
Have you 'reserved' some memory for the colors before? (with the 'ccPoinCloud::reserveTheRGBTable' method)
kasper
Post by kasper »
Sorry for post an incomplete code.
    BinFilter bin;
    BinFilter::LoadParameters lp;
    BinFilter::SaveParameters sp;
    ccHObject *obj = new ccHObject;
    bin.loadFile("origin_cloud.bin", *obj, lp);
    ccPointCloud *cloud = ccHObjectCaster::ToPointCloud(obj->getFirstChild());
    if (cloud->resizeTheRGBTable(true))
        for (int i = 0; cloud->size(); i++)
            ccColor::Rgb color;
            color.r = 255;
            color.g = 0;
            color.b = 0;
            cloud->setPointColor(i, color);  // <- crush in this line.
        bin.saveToFile(cloud, "cloud_color.bin", sp);
And the error shows:
erminate called after throwing an instance of 'std::out_of_range'
what(): vector::_M_range_check: __n (which is 36595) >= this->size() (which is 36595)
WargodHernandez
Post by WargodHernandez »
Should be
for (int i = 0; i < cloud->size(); i++)
