I'd like to georeference an OBJ file to a 2D CAD file (DWG format) and am not sure if CloudCompare supports this capacity. The DWG is an architectural footprint of an Italian city, and the OBJ file is a scan of a model of this city based on that footprint. Can you georeference an OBJ file to a 2D file in this software? If not, what other options are out there? Thanks very much for your time and help!
Georeferencing OBJ to DWG file
Re: Georeferencing OBJ to DWG file
No, sadly the DWG format is not supported (DXF only) and 2D registration won't work in the general case.
