Definition of center-points of 2D Polygons (facet)
Posted: Thu Aug 27, 2020 9:54 am
I generated different cross-sections along a cave-system with the segmentation tool and recieved different polylines. Based on those polylines I created surfaces by using the fit--> 2D Polygon (facet) Algorithm. For each surface the software calculates a center point and shows the coordinates of that point. My question is how CC determines these center points?
At the beginning I thought this point represents the center of mass of the geometry and this seemed plausible in some cases, at least by optical evaluation. But in some cases this point did not seem to be a real center point. I attached an image with one of those bad results (center point in "red").
I hope you can help me out.
Best regards
Michael
Best regards
Michael
