Contour lines only generating at top and bottom
Posted: Fri Aug 28, 2020 4:24 am
Hi All,
I am new to CloudCompare and found it after looking for an open source way of processing point clouds. I have recently purchased some land and found out I could get Point clouds of my land from the government. I wish to generate contours of the land to assist with designing water storage on the property. The point coulds are over large areas and not crazy dense so I cropped out the section I want with the data (1.7mb) said to have "an accuracy of 0.3m (95% Confidence Interval) vertical and 0.8m (95% Confidence Interval) horizontal "
The Issue I have is that when I generate the plots I get contours only at higher and lower parts and none on the middle (see attached Images). From viewing the dots I can see the contours forming nicely but but when using the rasta contour tool I just cant get them all. Any help or advice would be appreciated.
Regards,
Lachlan
Regards,
Lachlan
