parallel computing
Posted: Tue Sep 15, 2020 10:03 pm
by cvavrus
Hi there,
I am currently trying to run CANUPO via the command line to classify an extremely large point cloud. Currently, this operation has been crashing my computer, so I have been looking into running this process on a super computer available to me that I believe uses multiple cores. I do not know much about parallel computing, but I was wondering if you could help me to understand first of all if running CANUPO using parallel processing is possible and also how I would adjust the code to do so if it is possible. Hopefully this request makes sense.
Thanks very much,
Claire
Re: parallel computing
Posted: Wed Sep 16, 2020 3:16 pm
Normally the CANUPO plugin will automatically use multiple cores if available. Even on a standard PC, if you have multiple cores you should see all of them working (depending on the step of the algorithm, they can't be all parallelized).
And if it is a crash issue, then it's probably more the memory which is the limiting factor?
