Exporting contours as an image stack
Posted: Fri Sep 18, 2020 12:56 am
by ScottH
Using the extract cloud sections tool, I can generate multiple polyline cross-sections of my mesh. I can export these as many file types but I would like to export them as a sequence of images (e.g. sequence of jpgs/tif). in the z direction.
Is there a way to do this that someone might be able to suggest for me?
Regards,
Scott
Re: Exporting contours as an image stack
Posted: Mon Sep 21, 2020 5:02 pm
Well, the obvious answer it s that you can use 'render to file', but that would be manual and line by line!
Posted: Thu Oct 01, 2020 8:49 am
by ScottH
Hi Dan,
Yes, the render to file was the only option I have seen but manually rendering 2000 polylines is not going to be practical. Thanks, if anything comes to mind that will make it practical, I'd love to find out.
Regards,
Scott.
