Running CloudCompare in the Cloud
Posted: Sat Nov 07, 2020 12:32 am
Hello all, first post ;-)
I want to run these usages of CloudCompare in command line mode in a Cloud (AWS, GCP, Azure or other):
some of the used Flags (over different calls):
-MERGE_MESHES
-MERGE_CLOUDS
-C2M_DIST with -MAX_DIST and -MAX_TCOUNT set
storage format is BIN files
So my questions are:
- Can these calculations benefit from having a GPU available or are they always running on the CPU?
I think CPU only, just wanted to make sure.
- How parallelized are these calls, what number of cores would be a sweet spot between performance (low runtime) and price?
Are there any benchmarks that show speedup vs number of cores?
- How is the scaling regarding RAM? Is more RAM always speeding up calculations or only up to a certain point?
Or should I just try to run my models and increase RAM if CC crashes? Does CC crash if there is too little RAM, or does it just work slower?
- Is there something else to consider when running CloudCompare in the Cloud? ;-)
thanks for your time and/sharing your experiences,
rookie
-MERGE_MESHES
-MERGE_CLOUDS
rookie
