Point File Export
Posted: Tue Dec 04, 2012 1:36 pm
by Jim Kennelly
Great Program!
I am having trouble with the export of .pts or .txt
When importing .pts the file format is xyzirgb
When exporting the format is xyzrgbi
Files are from Leica Cyclone. Does leica have the wrong format?
Maybe a customizable output format for the wish list.
Thanks,
Jim Kennelly
Re: Point File Export
Posted: Tue Dec 04, 2012 1:57 pm
Thanks.
In fact there's no 'official' format. Everyone does as he pleases. This is why CC provides an import wizard.
Do you mean that Cyclone can't load back the ASCII files of CC?
Posted: Fri Dec 07, 2012 1:55 pm
by Jim Kennelly
Daniel,
We are primarily using your software to subsample large point clouds. We have found that Cloud Compare does an excellent job and the point clouds produced are more intuitive due to the even spacing.
We were hoping to go straight from cloud compare to Autocad to create a .pcg file. Autocad also expects xyzirgb.
Our work around is to re-import into cyclone which has a customizable import format like yours and then exporting to pts for Autocad.
A customizable export option would save the extra step.
Thanks again for a great product,
Jim
Posted: Fri Dec 07, 2012 10:06 pm
by Jim Kennelly
The solution might already be possible using the E57 format. All the software we use supports it and a plugin for autocad can be found here:
http://apps.exchange.autodesk.com/ACD/L ... collection
Thanks,
Jim
Posted: Sat Dec 08, 2012 9:03 am
Indeed, E57 is a very good exchange format.
Otherwise, we could add a small hack: if you use a particular extension for your exported ASCII file (.pts for instance) it would be easy to invert the default order in this case.
Posted: Tue Dec 11, 2012 2:51 pm
by Jim Kennelly
Daniel,
The only drawback with e57 is the default units of meter. Most of the time we are working in inches.
Perhaps next build we could put in a .pts format of xyzirgb.
Thanks again,
Jim
Posted: Wed Dec 12, 2012 12:17 pm
by MattPW
Daniel,
Would the hack you speak of be something that would require sourcecode modifications or is it something that could be done over a standard build downloaded from the website (I run in windows)
Just curious as I find myself in a similar position to Jim needing a specific order for exported .pts points.
Many thanks,
Matt
Posted: Wed Dec 12, 2012 12:56 pm
Yes I'll have to make small modifications to the code.
It will be available in the next official release version (hopefully before the end of the world ;).
Meanwhile you can use powerful text editors (such as Notepad++ on Windows) to swap columns (with ALT + SHIFT keys to select portions of text).
Posted: Sun Dec 16, 2012 9:29 am
Ok, so I've updated the code, this hack will be available in the next release.
However I realized that there's still something that might "annoy" other programs: as CC handles multiple scalar fields, the 'xyzirgb' format can become xyzi1i2i3rgb. So make sure to have only one SF per cloud...
