Near clipping plane is not working
christian077
Post by christian077 »
Hi! I really need to use the near clipping plane, but it's not working. I've already set the values on "Camera settings" and tried many times, but it just won't work: the points between my view and the target are still showing. What could it be and how can I solve it?
My version is 2.11.3
Thanks for your atention.
Re: Near clipping plane is not working
Are you in perspective projection mode?
christian077
I changed the projection mode and it worked, i did not know about that... thank you!!!
