Use CloudCompare as Git diff tool to check model difference
jindili
Post by jindili »
I want to configure CloudCompare as 3d model diff tool to check places been modifed between two git versions,
Now I just pass two .stl file path to CloudCompare, It launches the GUI and load these two stl models successfully,
But I need something further, can I pass some more options to CloudCompare to make it automatically Compute Cloud/Mesh Distance after these two stl files been loaded in the GUI.
I tried add optioin -C2M_DIST, but that make it run in command line mode, but I do need to launch the GUI.
Got no lucky to find any option I can use in the command line options list page:
https://www.cloudcompare.org/doc/wiki/i ... _line_mode
Re: Use CloudCompare as Git diff tool to check model difference
Well, you could first use the command line tool to compute the distances, and then launch CloudCompare to open the resulting file?
jindili
Post by jindili »
I'll go that way if it's the only way close to my needs.
But I think it would be much better if it's possible to load these two files in the GUI then compute the Cloud/Mesh distance since that way I could tweak those options interactively to get a better result which is not viable from the command line.
jindili
Post by jindili »
I manage to automate this task using Autohotkey Script,
It take me quite some time, so I post those staffs used in my workflow here,
It might help some if you need to do something similar.
Workflow in CloudCompare GUI:
  • select those two meshes imported in the DB Tree
  • Clik the Compute Cloud/Mesh Distance button
  • Clik OK on the Choose Role dialog
  • Move the Distance computation dialog to a left position not overlapping the 3d view
  • Uncheck the signed distance option on the Distance computation dialog
  • Send Enter to Compute and update the result in 3d view
and bind a hotkey to the Workflow, in my case Ctrl + x
Autohotkey script I used:
#IfWinActive ahk_exe CloudCompare.exe
^x::
Click, 150, 150
Send ^{Click, 150, 190}  ; Control+Click
WinGet, hWnd, ID, A
oAcc := Acc_Get("Object", "4.6.17", "ahk_id " hWnd)
oAcc.accDoDefaultAction(0)
WinWait, Choose role ahk_class Qt5QWindowToolSaveBits, , 2
if ErrorLevel
    MsgBox, WinWait timed out.
    return
WinActivate, Choose role ahk_class Qt5QWindowToolSaveBits
WinWaitActive, Choose role ahk_class Qt5QWindowToolSaveBits
Send {Enter}
WinWait, Distance computation ahk_class Qt5QWindowToolSaveBits, , 2
if ErrorLevel
    return
WinActivate, Distance computation ahk_class Qt5QWindowToolSaveBits
WinWaitActive, Distance computation ahk_class Qt5QWindowToolSaveBits
WinMove, 52, 515
WinGet, hWnd3, ID, A
oAcc := Acc_Get("Object", "4.5.1.1.5", "ahk_id " hWnd3)
Send {Enter}
return
^z::
Click, 150, 150
return
#IfWinActive
Software and Lib Scripts Used for the script above to work properly:
AutoHotkey
https://www.autohotkey.com/
Acc library (MSAA) and AccViewer download links - AutoHotkey Community
https://www.autohotkey.com/boards/viewt ... =6&t=26201
The acc path is kind a confuse, use tool linked below to get the right acc path
https://gist.github.com/tmplinshi/0fcb8 ... 8d0d974915
