M3C2 - how to save the points used in the search cylinder
MonicaPala
Post by MonicaPala »
I am using M3C2 to do a difference between a very dense point cloud from SfM and a very sparse point cloud that actually has GPS coordinates for validation. The second sparse GPS point cloud has around 100 points. So i used these points as core points. So for each core point the search cylinder has 1 point from the GPS point cloud and between 5 to 60 points from the dense SfM point cloud. Saving the M3C2 table i have the coordinates of the GPS points used as core. I would like to see and save also the points used from the dense SfM point cloud that were used in each search cylinder, maybe grouped with an id that identifies the core GPS point.
Is there any way to do that? My cylinders are small, 0.25 x 0.25 by 0.5 m height.
Thanks, take care,
Monica
Re: M3C2 - how to save the points used in the search cylinder
Hum, not with the current implementation. You would have to hack the code!
MonicaPala
Thanks. How can i find that code? I never tried to see the whole code of a plugin in CC as yet. Also, what language is in? Python or C++?
Thanks, take care,
Monica
It's C++: https://github.com/CloudCompare/CloudCo ... dard/qM3C2
But that's definitely not the simplest plugin...
MonicaPala
Thanks. I will see if any of my colleagues is good enough in C++ to extract the part i am after. Unfortunately i don't know C++ to do that myself.
Thanks, take care,
Monica
