Couple of small improvements
Darius_bd
Post by Darius_bd »
Hi, I was wondering if it could be possible to add two (hopefully) small improvements to the software:
- Separate decimals with a space, for easier readability:
Currently:
Idea:
Ideally that could be done also where you have to deal with the high number of points:
- Tick or untick all selected entities if they're selected:
The idea here is multiple entities are selected, ticking or unticking the checkbox would do the same for all the selected entities
Does it sounds good?
Re: Couple of small improvements
Ah, I think the first one was already attempted, but it didn't work as expected (can't remember the reason)
And for the second one, mind that you can achieve the same result with the 'a' shortcut, or with the 'Edit > Toggle (recursive) > Activation' menu entry.
Darius_bd
Post by Darius_bd »
Ha, that's really useful, I had no idea about that Toggle menu. Thanks for letting me know.
Regarding the first, perhaps it can be revisited, with the wisdom of the ages since the last time? :D
