Subsampling on axis
APOS80
Subsampling on axis
Post by APOS80 »
It would be nice to subsample by length on axis.
I use it for pointclouds thats from areal photos of the ground so the hight is on Z axis.
It would help to subsample with 0,5 on X/Y axis and 0,1 on Z axis.
Re: Subsampling on axis
Ah, that would make the algorithm much more complicated... well, a totally different algorithm actually.
JacekJaskolski
Post by JacekJaskolski »
You could try a workaround:
  1. scale the pointcloud along the Z axis only: x(1.0) y(1.0) z(5.0)
  2. apply subsampling (0.5)
  3. scale the cloud back: x(1.0) y(1.0) z(0.2)
This should give you a point cloud with 5 times higher density in Z than in XY
Ah, nice trick!
