Automatic Segmenation
Posted: Wed Nov 03, 2021 10:30 pm
by Camille
Dear Daniel,
first of all I want to thank you for all the precious support, your work is amazing :D
I come to the problem here below.
In September I successfully used the plugin for Automatic Segmentation of Bosché both for flat and curved surfaces. In that same work I observed that the tool was working only if the surfaces were XZ oriented.
The problem arose in the last two days, in which I was trying to do the same exact mortar perimeter extraction of the masonries, but the plugin seems not to work properly as before. The software version is always the same. Is it possible this thing?
I really hope you can illuminate me on this.
Best Regards,
Camille
Re: Automatic Segmenation
Posted: Sat Nov 06, 2021 7:42 am
Well, with the exact same software, it's a bit strange to have different results. Unless they use some random values? In this case you could try to run it several times?
