Calculating Snow height from Point Clouds
Posted: Thu Nov 25, 2021 4:10 am
by domi1711
we need to get information about the amount of snow on Rooftops.
We have laserscans of the buildings with and without snow, but i am unable to get find a solution myself.
I tried using MPlane, but it doesnt work, since it wont let me use the plane from Point Cloud A and then measure the distance to Point Cloud B.
Since the roofs are relatively complex structures, a simple plane comparison between point cloud A and Point Cloud B is not enough.
Can you provide me some tips what i could try? The ideal outcome would be a colored height map of only the snow, so you can see the individual thickness of the snow layer in one picture.
Thank you in advance!
best regards,
Dominik
Re: Calculating Snow height from Point Clouds
Posted: Sun Nov 28, 2021 9:08 pm
Are you able to properly register/align the two clouds?
Then you should use either Cloud-2-Cloud or M3C2 distance computation tools (see https://www.cloudcompare.org/doc/wiki/i ... omputation).
Posted: Mon Nov 29, 2021 5:18 am
by domi1711
Thanks for your input!
Aligning the clouds is a bit challenging, because one of the clouds is covered in snow, so to pick the 4 point pairs is difficult. Maybe we need to use ground control points to align them properly?
The automatic aligning function would be nice, but i think there would be problems because of the snow layer. Do you have any tipps on that matter?
best regards, Dominik
Posted: Mon Nov 29, 2021 8:12 pm
Yes, GCPs would be ideal indeed.
And if you really have snow everywhere on the second cloud, then indeed automatic alignment might not give a very reliable result ;)
