Unable to open RASTER grid .asc file with unicode characters in file path
Posted: Tue Jan 25, 2022 4:44 pm
Hey!
I am assuming this is both a known and low priority issue, so I thought I shouldn't open a specific issue on the GitHub tracker, but just in case I thought I should mention it.
I am using CC 2.12beta on Windows 10 21H2 with NTFS partitions.
When trying to open an ASCII Grid .asc file, using the Open dialog filter for RASTER grid, from a path containing Cyrillic characters (namely "D:\Споделена\example.asc") I get the following error: "An error occurred while loading 'example': unknown file".
Moving it to somewhere with ASCII chars only allows GDAL to read it properly.
I am also assuming this is not an issue with GDAL directly, since gdaltranslate (OSGeo4Win) seems to open the file just fine?
Maybe a hint about the error would be useful?
In any case, thank you for a truly awesome piece of software.
