3D triangulated model
Posted: Fri Feb 18, 2022 2:39 pm
Hello All. Please, how can I make a 3D triangulation model? I have a point cloud from scanning the tunnel and I need to make it a 3D triangulation model. I tried it through poissonRecon. But I was not satisfied with the result. Because if I compared the network with the points I created it the deviations were somewhere over 3 cm. Maybe I made a mistake somewhere in normalization or in defining parameters, but I tried different variants and the result was always the same. I need to make a 3D model so that my points from the scan are the "corners" of the triangles. So if I compare the points with the network, let the deviations be minimal. Can you please achieve this nicely? I will be very grateful for any help.
