Best Fit Sphere Command Line
Posted: Tue Apr 19, 2022 5:57 pm
by caudete69
I would suggest adding something like -BEST_FIT_SPHERE to the command line options. I'm currently using cloudcompare in the command line to automatize measures. The BEST_FIT_PLANE is working perfectly and is easy to put into a bash file. I need the same but for SPHERE.
Thank you in advance. Keep the great work!!!
Re: Best Fit Sphere Command Line
Posted: Thu Apr 21, 2022 2:54 pm
What output would you expect? The fitted sphere as a mesh (in memory) or something else?
Posted: Thu May 05, 2022 7:42 pm
by caudete69
Sorry for the delay in answering.
I expect something similar as in BEST_FIT_PLANE, the mesh in a file if possible. Another possibility could be the radio and center of the sphere as answer.
Thank you!!!
Posted: Sat May 07, 2022 12:26 pm
I added it to the (way too long) TODO list.
