How to set image2D structures to .e57?
Bob
Post by Bob »
Hi ,
I try to use obj to export e57 file, and import to other software. But getting a issue, I can't understand, Could help me answer the problem?
the issue is :
[ FAIL ] E57 shall contain one or more Image2D structures that have either 'sphericalRepresentation' field or 'pinholeRepresentation' field.
Thinks.
Bob
Re: How to set image2D structures to .e57?
In which software are you seeing this message?
Because E57 don't contain necessarily image2D structures (that's optional). Maybe it's a software that needs these images?
sagee.sch
Post by sagee.sch »
was this solved?
trying to import an E57 file to Vuforia Area target generator from a cloudcompare (an OBJ file converted to cloudpoint)
thoughts?
