Command line saved clouds not readable in CC
Posted: Mon May 23, 2022 5:28 pm
Hi:
Thank You for your answer. The new version solved certain problems and generated clouds per inline commands are already readable.
Now I have another problem with inline commands: I want to save the result of -C2C-DIST in a file of my choice. I'm using -AUTO_SAVE OFF at the beginning and -SAVE-CLOUDS FILE filename at the end.
My command: command2=[diretoryCC 'CloudCompare -SILENT -AUTO_SAVE OFF -O ' compnuvem ' -O ' refnuvem ' -C2C_DIST -SAVE_CLOUDS FILE ' output_interm_nuvem3]
Nothing happens. If I do not use -AUTO_SAVE OFF , it works, but an automatic name is assigned to the resulting file and it lands somewhere, making it difficult to process the result further.
What have I made wrong? -MERGE and -FILTER are working fine. Only -C2C_DIST is giving me this problem.
Any help? Thanks
Paula
Any help? Thanks
Paula
