Locking Clouds for Level Tool/ Orientation Change
Posted: Mon Jun 13, 2022 10:17 am
Dear CC Enthusiasts,
May I ask if anyone can help with the following?
I would like to "lock" several aligned clouds together and use the level tool on them. The clouds are already aligned, but whenever I mark more then one cloud, the level tool shows the error/ command "Select an Entity". Just levelling one cloud alone is not an option, as there would be way too much work involved to level dozens of clouds again, and to merge the clouds is unfo also no option, as they need to be kept separate.
Many thanks for reading this!
