import control points from ascii file
OlaS
Post by OlaS »
First of all, great work!!! Thank you very much for all your efforts!
What about adding a possibility to import coordinates (from ascii) of control points for pairwise point cloud alignment (registration)?
This function would be great for scaling point clouds reconstructed from geo-tagged images!
Best,
Ola
Re: import control points from ascii file
Yes, why not. How do you see this option: using two separate files with the same number of points, or use a single file with 2 (equivalent) points per line?
By the way, the next release will present a new option to determine scale for the ICP algorithm. So you should be able to achieve almost the same result this way (open your 2 clouds of control points, roughly register both sets, apply the ICP registration with free scale then get the matrix and apply it to the true clouds).
OlaS
Post by OlaS »
Sorry for my late reply. I guess 2 separate files would be easier for people who do not program, both options are fine for me :-)
Best regards,
Ola
