Add new plane using the 4 coefficients of the plane
Posted: Fri Jul 08, 2022 12:47 pm
I have not found a way to create a new plane using the 4 coefficient of the plane.
The first 3 are the normal, so i can create a plane with the correct inclination, but i need to include the 4th coefficient since the height with respect to the origin is important.
I want to check if a fitted plane is adequate for a point cloud, but the plane is generated using another program and i only have the coefficients since i will be computing distances and it is easier to do with the coefficients.
Is there any way to just put the 4 coefficients to create a plane?, or where can i put the 4th one to offset the plane to the correct position?
Also, is there a way to restrict the render of the plane to a range of coordinates, without having to use the size and center?
