Gap filling
T1230321
Gap filling
Post by T1230321 »
Hi everyone,
Complete novice here.
I'm wanting to fill some small gaps I have in my scans. Could someone tell me the best way to do this, please?
I have seen other forum posts discussing the topic by using plugins, but I'm not sure how, or where, to get these from.
Any help would be much appreciated.
Some info:
Scanner - FARO X330
Scans processed in Faro Scene and exported as ASCII file
Corresponding xyz file imported into CloudCompare.
Re: Gap filling
I guess the only reliable way to do this is to mesh the cloud (at least locally) with one of the 2 meshing approaches (Delaunay or Poisson - see https://www.cloudcompare.org/doc/wiki/index.php/Methods and https://www.cloudcompare.org/doc/wiki/i ... n_(plugin)) and eventually sample points on the resulting mesh.
But frankly, that looks quite painful ;)
T1230321
Re: Gap filling
Post by T1230321 »
Thanks, Daniel, I will give this a go!
DA523
Re: Gap filling
Post by DA523 »
- draw plolyline around the hole
- sample polyline into points(1000 points)
- mesh the new points
- sample mesh into points
- merge new points into scan points
- delete extra ployline and mesh etc
T1230321
Re: Gap filling
Post by T1230321 »
Hi DA523,
Thanks very much for your reply.
I followed that up until point 5.
How do you go about merging the new points into scan points? The 'merge' option is greyed out for me.
Thanks in advance
DA523
Re: Gap filling
Post by DA523 »
control+D to select 2 pointsclouds then click merge button
T1230321
Re: Gap filling
Post by T1230321 »
Thanks for your help!
