There is an small bug in alpha, when having the same CC session open, as you add more .las that have an illuminance__PCV SF, it when opening new files keeps stacking illuminance__PCV SF's, like it does not resset the text field.
EDIT: I just realized looking at the image that same occurs with regular SF's, like there are a *hitload of them.
[FIXED][small bug] [latest alpha] when opening, too many SF
Re: [small bug] [latest alpha] when opening, too many SF
Hum, is it really the latest alpha version? Because that's something that was fixed a last month I believe :(
I've downloaded instlaller and zip, I'll try both and report back
Hello, sorry for the delay.
I downloaded both the zipped and the installer.
Tested both.
Occurs in both versions.
Download date 12/01/2022 ( EU date format)
Tested both.
Ok, that's strange, but indeed the bug was back! This will be fixed in the next alpha release (probably online before Monday).
