Hi all, I am very new to CloudCompare and I am trying to analyse high throughput cloudpoint data. I am using HPR plugin and it gives me a file with the extracted reduced file, but is there a way to do that in command line mode so that I can automate the task for all my images?
Thanks in advance
Hidden Points Removal and export using command line
Re: Hidden Points Removal and export using command line
Sadly this plugin needs the (OpenGL) camera position and orientation, and the command line doesn't have any graphical context/display capabilities.
Someone would have to rework the code so that it can be called via the command line, still specifying a view point and a view direction.
