Complex Mesh
Posted: Fri Jul 26, 2013 12:56 pm
by ccwbarry
I've managed to open a point cloud from Cyclone in .pts format in CloudCompare. I'm trying to run a mesh on it but getting the error "Cloud must have normals!"
Anyway around this? I'm no expert in these things! Any help you can provide would be great.
Christian
Re: Complex Mesh
Posted: Sat Jul 27, 2013 8:21 am
There's 2 ways of computing normals:
- either use 'Edit > Normals > Compute' (one the cloud is selected)
- or you can try the qPCL plugin (Compute normals)
You'll se that depending on your cloud shape it's not always easy to get a clean result... good luck ;)
Re: Complex Mesh
Posted: Mon Jul 29, 2013 12:10 pm
by ccwbarry
I've computed the normals via the qPCL plugin with a search radius of 0.0201 - the default settings. When I run the Poisson Reconstruction my results aren't great. When I increase the value to above 10 the program becomes unresponsive. Do you know of anyway around this? My point cloud is quite complex and has over 6m points - maybe this could be the issue?
Cheers,
Christian
Re: Complex Mesh
Posted: Tue Jul 30, 2013 9:42 am
Indeed, for very complex shapes you'll need to use higher levels (11, 12, etc.). And you'll need very clean normals (i.e. all oriented in the right way, smooth, etc.).
Re: Complex Mesh
Posted: Sun Aug 04, 2013 1:31 pm
by ccwbarry
Having fun playing with the program :)
Just another quick question, if there anyway to see the attributes of the mesh I've created? Number of faces, etc?
Cheers
Re: Complex Mesh
Posted: Sun Aug 04, 2013 3:58 pm
Either select (click on) the mesh and then look at the 'properties' panel on the bottom-left. Otherwise, right click on the mesh entry in the database tree and then select the 'Information (recursive)' entry.
