CC won't launch
eliscio
CC won't launch
Post by eliscio »
Hello All,
Trying to get CC to open on a new laptop. It's Win 11.
I tried the current 2.12 release and the 2.13 alpha. Basically, when I double click on the icon, the spinning wheel shows up and after a second, it disappears and nothing happens.
I tried to look through some old threads here and installed the FARO SDK, tried to uninstall and then reinstall without the FARO SDK. I also tried to modify the Registry to remove one of the CC folders and still nada.
Any ideas?
Thanks!
Re: CC won't launch
Hi Eugene,
To me it looks like a graphic card issue? Have you tried to update the drivers? And do you have a GPU and a chipset on this laptop maybe? Can you try to force one or the other to be used when launching CC?
nrpage
Re: CC won't launch
Post by nrpage »
Hi, I am having the same problem. I am working on a virtual machine and the display adapter is listed as Microsoft Hyper-V Video.
I've tried installing a couple different versions of CC (both the latest stable Win64 version [2.12.4] and the latest beta [2.13.alpha]). Both installs have behaved in the same way that Eugene describes: double click on the icon, the spinning wheel shows up and after a second, it disappears and nothing happens.
Please let me know if you find a solution.
Thank you.
Re: CC won't launch
Well, for a virtualization scree/device, I'm not that surprised. CC needs a real GPU to work.
