Good morning!
I'm currently using grasshopper's plugin Volvox to work with point clouds. There's a grasshopper function named Command Line that uses some CloudCompare commands. The info says "See commands at http://www.danielgm.net/cc/doc/wiki/ind ... ommandLine" but the web is shut down. Does anyone else know where can I see these commands?
Thank you and sorry if it's a somewhat basic question.
Volvox Command line commands.
Re: Volvox Command line commands.
The real link is https://www.cloudcompare.org/doc/wiki/i ... _line_mode
