Accuracy scan system
Ibanski
Post by Ibanski »
Hi all,
I know this is a rather general question, but after building a laser scan system, I need to check its accuracy..
First I can generate a point cloud with Matlab, but now I want to use CloudCompare to compare it with an original Inventor model.
Is there a way to import this inventor drawing in Cloudcompare? Or do I have to convert it to a point cloud first..
Or is this method just ridiculous and is it more efficient to convert my point cloud to a CAD model and compare it somewhere else :)
Re: Accuracy scan system
This seems quite a good idea ;)
You just have to convert your Inventor model to a format that can be imported by CC: OBJ, STL, or PLY. Then you'll be able to compute the distances between the points and this model (as a reference).
