Job Done Message
Posted: Tue Aug 29, 2023 5:45 pm
by fifty8ch
Hi@all.. is there a way in a batch processing the job message (job done) per command parameter to auto accept or disable it?
Re: Job Done Message
Posted: Sun Sep 03, 2023 1:06 pm
You should simply use -SILENT to avoid this message to appear? (and any other dialog as well)
Posted: Fri Sep 08, 2023 8:35 am
by fifty8ch
if i do this...nothing happen. the silent option isnt working for me
Posted: Thu Sep 14, 2023 10:37 am
by fifty8ch
Anyone has a soultion or workaround?
Posted: Sat Sep 16, 2023 10:09 am
What do you mean by "nothing happens"? Have you put the option at the beginning of the command? (after 'CloudCompare')
Posted: Wed Sep 27, 2023 12:51 pm
by fifty8ch
yes i did.. no operation starts and no log is written. If i started without the silent option, all batch command works
Posted: Thu Sep 28, 2023 7:05 am
Which version were you using?
