Dear all,
On one hand, I read a lot of question/answer about the ICP-based fine registration implemented in CC, which helped me in understanding the tool. So many thanks to all.
On the other hand, I think that one (relevant) question have not been posted and discussed:
for the tranlation component of the coordinate transformations, is the computed matrix dependant to the used global shift? Is there a way to export an "independent" version of the transformation matrix other than setting the global shift to 0? maybe it could be useful if someone is planning to use the tranformation matrix in other software..
Thanks,
All the best for all,
Mauro
ICP-derived transformatin matrix clarification
Re: ICP-derived transformatin matrix clarification
With the latest versions (2.13 at least), the 2 matrices will be output in the Console. One that translates the to-be-aligned entity locally, and the other one that translates the global/original coordinates.
Many thanks Daniel.
All the best.
All the best.
