C2M distance values
GabrielMulero
C2M distance values
Post by GabrielMulero »
Good day, I am calculating the CHM of my data, however, I would like to save the point cloud with the C2M distance data. I don't want to save it as an ASCII file. Do you know how I can go about this? Also when I save the as Ascii, it doesn't save the intensity data.
Re: C2M distance values
You could use the PLY format? (binary, and can save any kind of scalar field). The LAS format will also support scalar fields (with EVLR) if you use the latest 2.13.beta version.
GabrielMulero
@daniel Thank you. I have been able to work around it.
