Poisson Surface Reconstruction
Posted: Thu Dec 07, 2023 6:06 pm
by DiogoPinho
Greetings
I am currently writing my master thesis and I use CloudCompare's Poisson Surface Reconstruction in it.
Is this plugin based in the article by M. Kazhdan and H. Hoppe?
I am asking this to know if I can cite this article in the thesis as the basis for this plugin.
Thank you for your help and for the amazing software that is cloud compare!
Re: Poisson Surface Reconstruction
Posted: Fri Dec 08, 2023 9:11 am
Yes, this plugin directly uses the PoissonRecon library from M. Kazhdan.
So I guess you should cite their work primarily (and maybe say somewhere that you used it via CloudCompare?)
Posted: Tue Dec 19, 2023 7:56 pm
by DiogoPinho
Great, thank you very much!
And yes I will not only cite the paper, but also reference the method and algorithm used in CloudCompare.
Thank you again!
