Is there a way to rotate model 90 exactly degrress ?
Posted: Thu Dec 14, 2023 2:51 am
by Jay_Ki
I want to rotate my 3D model exactly 90 degrees on either the y or x axis around an object.
I can get close to 90 degrees by using the rotate tool and rotating by hand, but sometimes it doesn't seem accurate.
Is there a way to rotate the model exactly as I see it, just by entering a 90 degree figure?
Re: Is there a way to rotate model 90 exactly degrress ?
Posted: Thu Dec 14, 2023 8:23 am
Just use the 'Edit > Apply transformation' tool (second tab).
https://www.cloudcompare.org/doc/wiki/i ... sformation
