contour line and profile line
tsyxulei
Post by tsyxulei »
Hi
Thanks for your provider this wonderful source .I want to create contour line and profile line Can you provide some advises?
Re: contour line and profile line
For the moment, the only available tool is the "Point List Picking" tool (main toolbar) that let you pick several points then export this selection as a polyline.
But sadly you won't be able to export this polyline other than as a point cloud (i.e. a file with only the polyline vertices).
We hope to add one day:
- a mean to automatically extract contours (from slice obtained with the cross-section tool typically)
- a mean to export those contours to DXF (this one should be available soon)
tsyxulei
Post by tsyxulei »
Thank you for your rapid reply .And I expect your contour tools release
