polyline export format for Surface of Revolution Analysis plugin (plugin)
Posted: Thu Feb 08, 2024 3:39 pm
Hello everyone,
I'm currently working on the dimensional analysis of a pipe. I would like to make 2D maps of the degradations present on the pipe in question.
In my research I came across the "Revolution Analysis plugin (plugin)". This tool seems ideal for my application, but I can't manage to export my polyline correctly in the format accepted by the plugin.
The format in question is available by clicking on this link :
https://www.cloudcompare.org/doc/wiki/i ... 8plugin%29
I'd like to know if there's a trick to exporting polylines directly in this format.
I'd also like to know whether this profile should be transverse or longitudinal in relation to my object, as I've seen both on the net.
I can only export txt files in XYZ format when it comes to radius and line height.
I've tested the various export formats, converting them into txt and none of them give me what I want...
HELP!
Thanks for reading
HELP!
Thanks for reading
