[FIXED] Not loading ASCII File with empty line
suby
Post by suby »
I used latest CloudCompare version (2.5.1) binaries for windows, and cloud compare freeze when loading an ascii file with blank lines. Program freeze, and memory usage always increasing (until all physical RAM is reserved by cloudCompare, ie 6Gb).
I've tested both win32 an x64 versions.
My points format is X Y Z Grey (tab separated) with approximatively 2 millions of points. If i remove the blank lines (one in the middle of my file and another at the end), cloud compare will load file just fine, in only few seconds.
I've also tested with a small extract of my file (only 500 points) and the bug also occurs.
Thanks.
Re: Not loading ASCII File with empty line
Thanks for the feedback! The bug is fixed on the github repository.
The fix will be available in the next version...
suby
Post by suby »
OKi, I've tested with the github version and it's working.
thanks
