Compass Tool Won't Create Measurements
Posted: Fri Mar 08, 2024 4:19 pm
by parker2020
I am trying to take measurements of an outcrop on a georeferenced model. I have exported the model from Metashape with texture and successfully imported the model into Cloudcompare. I have seen videos on how to use the compass plugin to take measurements of planes, but in the video when they click on the points, there is a measurement that populates the "measurements" tree. When I do it, it creates the measurement tree, but doesn't add any actual measurements to the tree... any ideas on why it won't record the measurements?
https://www.youtube.com/watch?v=waZUZY-_-fo
Re: Compass Tool Won't Create Measurements
Posted: Sat Mar 09, 2024 8:30 am
So I've not been able to reproduce your issue with version 2.13.
If I click a point cloud, then I can see a 'plane' object created, both in the 3D view and the DB tree.
If I click another entity, I dont' see anything created.
Can you maybe share a little bit more information? (screenshot, or even better a file - you can send it to admin@cloudcompare.org).
