Transation XY plane
cloudMEETHET
Transation XY plane
Post by cloudMEETHET »
Hi!
I have a question on the translation matrix that I use combined with the command line.
I have to do a sipmle translation, but it won't work.
the result gives me wrong coordinates
Input is an E57 point cloud with only +-100 points.
Translation matrix:
1.000000000000 0.000000000000 0.000000000000 -60306.533000000000
0.000000000000 1.000000000000 0.000000000000 -434989.17700000000
0.000000000000 0.000000000000 1.000000000000 0.000000000000
0.000000000000 0.000000000000 0.000000000000 1.000000000000
The first coordinate of the original E57 is
65919,409 441511,444
Aftern translation it should be
5612.875
6522.268
but it gives
5612.875
6522.250
so the Y coordinate is not matching.
I have put the original E57 and the translation matrix here: https://we.tl/t-uKMNhUKIi8
I have used every possible setting with
set gloal shift 0 0 0
drop global shift
global shift auto
none of thse options work.
Could anyone help me in this case?
Thx
Re: Transation XY plane
The issue is indeed with the Global Shift (if not right, you'll lose accuracy). And in your case, you'll lose accuracy anyway because it will happen at loading time (if you don't apply a Global Shift) or at the translation time (because the command line mode won't suggest you to impact the Global Shift instead of the cloud coordinates...). Luckily, the 2.13.x versions now have a -APPLY_TO_GLOBAL option after -APPLY_TRANS to do exactly that!
