Merge jpg Textures + offset.xyz missing
Posted: Fri May 10, 2024 12:03 pm
by Manisch
Hi there,
When I use CloudCompare to merge multiple obj files, is there a way to also merge the jpg textures?
It always outputs multiple jpg files, when I try it.
Also, I need an offset.xyz file, which seems to be missing after exporting the model from CloudCompare. Is there a way to get it, as well?
Re: Merge jpg Textures + offset.xyz missing
Posted: Sat May 11, 2024 8:15 am
No, CloudCompare cannot do any fancy things with textures...
And I'm not sure to know what an 'offset.xyz' file is?
