abdulaerodyne
Posts: 2 Joined: Thu May 30, 2024 8:54 am
Post
by abdulaerodyne » Thu May 30, 2024 9:06 am
I'm trying to convert a mesh PLY file to a point cloud and trying to export that point cloud in LAS/LAZ file formats.
I can do that with GUI but I'm facing the following error via linux command line:
Command:
CloudCompare -SILENT -VERBOSITY 1 -AUTO_SAVE OFF -o abc-ply.ply -SAMPLE_MESH POINTS 10000000 -C_EXPORT_FMT LAS -EXT LAZ
OS: Ubuntu 22.04.4 LTS
CC version: 2.13.1 (Kharkiv)
Is there anything I'm doing wrong?
Posts: 8193 Joined: Wed Oct 13, 2010 7:34 am
Post
by daniel » Thu May 30, 2024 3:58 pm
Ah, maybe that's the LAZ format that's not supported? Does it work without the end part? (-EXT LAZ)
abdulaerodyne
Post
by abdulaerodyne » Fri May 31, 2024 7:39 am
No, it doesn't work without -EXT as well.
Command used for reference:
CloudCompare -SILENT -VERBOSITY 1 -AUTO_SAVE OFF -o abc-ply.ply -SAMPLE_MESH POINTS 1000000 -C_EXPORT_FMT LAS
Still getting:
Update:
Getting similar error on E57 file type as well.
CloudCompare -SILENT -VERBOSITY 1 -AUTO_SAVE OFF -o abc-ply.ply -SAMPLE_MESH POINTS 1000000 -C_EXPORT_FMT E57
Getting:
Post
by daniel » Mon Jun 03, 2024 8:04 am
It's as is the command line mode was not loading the I/O plugins... You should see the list of plugins loaded at the beginning of the logs (in both the GUI and the command line versions).
